Extrusion Head Fan
2 Risposte Punteggio 1 |
Printer that is not initializing correctly and skipping? |
Why isn't my printer turning on? |
Strumenti
Questi sono alcuni strumenti di uso comune usati per lavorare su questo dispositivo. Potrebbe non essere necessario ogni strumento per ogni procedura.
Troubleshooting
For more information regarding common troubleshooting issues, please see UP! Plus 2 Troubleshooting.
Background and Identification
Device Name: UP! Plus 2
Release Date: June 1st, 2013
This particular printer was the first to offer automatic bed leveling and automatic height adjustments, allowing for it to be considered one of the easiest 3D printers to use on the market to date.
The earliest revisions of the printer came with optical height detection switches for the auto-leveling process which were later replaced by the more precise mechanical switches. However, the version of height detection switch will not affect your repairs, as the switch is an external part that is only used during the auto-leveling process.
Specifications
Model Number: 3DP-14-4D
Printer Size: 245mm Wide x 260mm Deep x 350mm High (9.5 x 10.5 x 14 inch)
Weight: 5 Kg (11 lbs)
Supported Operating Systems: Windows XP, Windows Vista, Windows 7, Mac
Build Size: 140mm Wide x 140mm Deep x 135mm High (5.5 x 5.5 x 5.3 inch)
Build Material: ABS and PLA Plastic
Layer Thickness: Variable between 0.15/0.20 /0.25 /0.30 /0.35 /0.40 mm
Additional Information
Community forum for UP brand printers
UP! Plus 2 Advanced User Guide
