Hard Drive
Nessuna Risposta Punteggio 1 |
My daughter's laptop keeps configuring and then it shuts down |
Nessuna Risposta Punteggio 0 |
black screen ,blue and white question enter password |
1 Risposta Punteggio 0 |
How to remove windows midia center |
Strumenti
Questi sono alcuni strumenti di uso comune usati per lavorare su questo dispositivo. Potrebbe non essere necessario ogni strumento per ogni procedura.
Background
Toshiba’s Equium A210 laptop is a business-oriented version of the Satellite Pro A210 and Satellite A210 laptops. While there are some minor hardware differences, most components are interchangeable between the three units and require a Phillips #1 Screwdriver to repair. The primary differences between the Equium are the software packages included at the time of purchase, drivers, and warranty coverage.
Before replacing components (e.g., memory chips, video cards, power supplies, etc.), check the specification sheets for additional information and the component labels to ensure the correct replacement is being used.
Toshiba discontinued production of laptops in 2020 and sold its stake in the PC business to Sharp. In turn, Sharp renamed the subsidiary division Dynabook. Hardware specification sheets, knowledge bases, and driver support/updates are available through Dynabook.com.
Identification
The Toshiba Equium A210 is an onyx-blue laptop consisting of a base with a flip-top monitor with a 15.4 inch (39.1 centimeter) viewable screen. The unit’s base has an integrated keyboard and mouse touchpad, USB ports, and CD-RW drive, measuring 14.3 inches (36.3 centimeters) wide by 10.5 inches (26.8 centimeters) deep, with a height 1.54 inches (3.9 centimeters) when closed. The unit’s weight is 6.1 pounds (2.8 kilograms). The unit requires an AC 120/230V (50/60 Hz) power adapter.
As part of the A210 series, the hardware components and virtually identical to the Satellite/Satellite Pro laptops, with the primary difference between the two platforms being warranty and software bundles. Some customization was possible, but the base unit was comparable to other A210 system models. Most Google searches for the Equium variant will redirect to pages to the Satellite/Satellite Pro A210 models.
To find the model and serial number for your specific device, find the product identification sticker or laser-etched plate affixed to the underside of the unit's base.
Technical Specifications
Most Google searches for Toshiba Equium A210 specifications redirect to the specifications for the Satellite/Satellite Pro A210; most hardware components are interchangeable. However, ProductInDetail.com lists the following system specifications:
· Display: 15.4-inch (39.1-cm) LCD monitor with 1280x800 WXGA resolution
· Processor: Dual-Core AMD Turion 64x2 mobile technology TL-60/2 GHz
· Chipset: AMD M690V
· Memory: 2 GB (2x1 Gb) DDR2 SDRAM base, max expansion to 4 GB
· Hard Drive: 160 Gb HDD SATA 1.5 Gb/s 5400 rpm
· Graphics Processor: ATI Radeon X1200
· Wireless Adapter: 802.11B/G
· Ethernet Adapter: 10/100 Ethernet
· Battery: 4000 mAh Lithium Ion
· AC Adapter: AC 120/230 V (50/60 Hz)
· Operating System: Microsoft Windows Vista Home Premium
ProductInDetail Website Source
Additional Information
Toshiba Equium A210 Specifications
Toshiba Satellite Pro A210 Downloadable Product Specifications
Toshiba Satellite A210 Specifications
Toshiba Satellite A210 Series User Manual
Toshiba Satellite A210 Series Maintenance Manual
Toshiba Satellite A210 Drivers
