Battery
1 Risposta Punteggio 0 |
Why does the flash not flast |
How to factory reset the camera |
Dropped camer in water can it be repaired |
Lens shudder disassemble instructions |
Documenti
Strumenti
Questi sono alcuni strumenti di uso comune usati per lavorare su questo dispositivo. Potrebbe non essere necessario ogni strumento per ogni procedura.
Background
The samsung WB850f came out in February 2012. It is a 16.1 megapixel camera with a 3in. LED screen. Works better in high sunlight compared to other cameras with similar specs due to 16.2 megapixel BSI(back side illuminated) CMOS sensor. The WB850f has built in features like wi-fi, gps functionality, 21x optical zoom, and 23mm wide-angle lens. For photos the camera’s battery life is 100min/200 photos and for videos it is 85 minutes.
Identification
It is identifiable by it’s Samsung logo, “21x” in the bottom right corner in the front and “full HD” in the top right in the front. The HD is shaded white. It also should say WB850F in white on top.
Technical Specifications
• Effective Picture Resolution : 16.2 Megapixel
• Memory Card Slot : SD Memory Card, SDXC Memory Card, SDHC Memory Card
• USB Port(s):USB 2.0
• Battery Type : Samsung SLB-10A Li-ion rechargeable battery
• Dimensions (Approx.) : 109.5×62.2×24.9(35.1)mm
• Weight (Approx.) : 232g (without battery and memory card media)
