1 Diagramma
Domande popolari nel forum
Fai una domandaNon ci sono domande. Puoi essere il primo a porre una domanda!
Background
RIDGID was established in 1923 and has created tools for professionals of different trades. The 14233 S36 Bolt Cutter has hardened alloy steel center-cut jaws and grip handles. It can be used to cut a variety of objects, including bolts, chains, padlocks, rebar, screws, rivets, wire, steel, heat-treated rods, reinforced rods, and spring wire.
This tool can be used for many types of work in many different fields, including construction, mechanical, plumbing, landscaping, and for anyone doing home or yard repairs.
Identification
The brand name RIDGID is located on the handle grips and jaws. The model number of the device is on one of the jaws.
It is the only RIDGID bolt cutter that is 38 inches, being the second largest one, with the largest being 44 inches and the smallest being 15 inches.
Technical Specifications
- Dimensions: 39.01 X 11.5 X 3 inches
- Weight: 13.45 lbs
- Manufacturer: RIDGID Tool Company
- Item Model Number: 14233
- Length: 38 inches
- Capacity for Soft Metals (15RC)1: 9/16 inches
- Capacity for Medium Metals (31RC)2: 1/2 inches
- Capacity for Hard Metals (42RC)3: 7/16 inches
- Color: Red and Black
