Analog Stick
3 Risposte Punteggio 1 |
Where can I get a plastic ABYX pad that goes inside the controller? |
1 Risposta Punteggio 0 |
Where do I find replacement bumpers |
2 Risposte Punteggio 2 |
Where can I buy the correct trigger spring |
Strumenti
Questi sono alcuni strumenti di uso comune usati per lavorare su questo dispositivo. Potrebbe non essere necessario ogni strumento per ogni procedura.
Troubleshooting
For more information regarding common problems with this device, go to
PowerA Fusion Controller for Xbox One Troubleshooting
Background
Officially licensed by Microsoft, the PowerA Fusion Controller is designed for Xbox One and has 6 interchangeable analog sticks, 2 quick-trigger locks, and 2 advanced gaming buttons, mappable to the settings of choice, to enable fine-tuned accuracy and improved speed. Finished with gold electroplated elements, breathable grips, a 3.5mm audio input, and 9.8ft braided cable.
The controller has some fame because buttons can get stuck and fail in a short period of time. Additionally, it has poor quality screws, so be prepared to break the exterior of the controller if you need to open it.
This controller is different from other PowerA controllers because it is completely black and has a striped design where you hold the controller to provide a better grip, the back also has a braided texture that differences it from others.
Identification
The PowerA Fusion Controller can be identified by its model number: 1428680-01. This can be found on the sticker on the bottom side of the controller.
Additional Information
Official PowerA Fusion Controller Page
