5G mmWave Antenna
1 Risposta Punteggio 1 |
How to replace the rear assembly. |
2 Risposte Punteggio 2 |
Pixel 8 Pro Charging Coil location |
1 Risposta Punteggio 0 |
want to purchase back glass and frame for pixel 8 pro but do you have |
How can I remove the microphone, cameras and/or sensors? |
Documenti
Ricambi
Strumenti
Questi sono alcuni strumenti di uso comune usati per lavorare su questo dispositivo. Potrebbe non essere necessario ogni strumento per ogni procedura.
Modelli
G1MNW, GC3VE
Background
Announced on October 4th, 2023, the Pixel 8 Pro continues Google's flagship smartphone line with updates to its camera and processor. With only minor changes to the wide and telephoto cameras, and an upgraded ultrawide camera, the new Google AI integration allows for higher quality photos for smaller objects, a.k.a. "Macro Focus," and more options for in-app editing. The Google AI is possible via the new Google Tensor G3 processor, which has improved performance and efficiency compared to the Tensor G2.
The Google Pixel 8 Pro starts at $999 USD.
Identification
The Pixel 8 Pro can be identified primarily by its model number: G1MNW, GC3VE, or GE9DP, which can be accessed by looking at its original box or navigating to "Settings" >"About phone" and then scrolling down and tapping on "Model & Hardware."
If you lost the original box or can't access the Settings app on your device, you can also identify the Pixel 8 Pro by its signature camera bar that protrudes as a wide strip along the top edge of the back cover. Compared to the Pixel 7 Pro that had one oval-shaped camera cutout alongside a circular cutout, the Pixel 8 Pro's camera cutout is a single ellipse.
The Pixel 8 Pro comes in three colors: Bay, Obsidian, and Porcelain, and Mint.
Repairability
For a detailed look at the pros and cons of repairing the Pixel 8 Pro, see the attached report.
Technical Specifications
- CPU: Nona-core (1x3.0 GHz Cortex-X3 & 4x2.45 GHz Cortex-A715 & 4x2.15 GHz Cortex-A510)
- GPU: Immortalis-G715s MC10
- Chipset: Google Tensor G3 (4nm)
- Memory: 12 GB LPDDR5X RAM
- Storage: 128 GB, 256 GB, 512 GB, or 1 TB of UFS 3.1 internal memory
- Display
- 6.7 inch panel
- 1344 x 2992 pixels (~489 ppi)
- Super Actua OLED, HDR10+, LTPO, 1–120Hz
- Cameras
- Main Cameras:
- 50 MP, 1.2µm, ƒ/1.68, 82˚ FoV (wide), 1/1.31" PDAF, OIS
- 48 MP, 0.8µm, ƒ/1.95, 125.5˚ FoV (ultrawide), PDAF
- 48 MP, 0.7µm, ƒ/2.8, 21.8˚ FoV (telephoto), 5x optical zoom, PDAF, OIS
- Front-facing Camera: 10.5 MP, 1.22µm, ƒ/2.2, 95˚ (ultrawide), PDAF
- Google AI Integration
- Main Cameras:
- Ports and Connectivity
- Wi-Fi 802.11 a/b/g/n/ac/6e/7, tri-band, Wi-Fi Direct, hotspot
- 5G Sub 6GHz / mmWave, LTE
- Bluetooth v5.3
- GPS, GLONASS, BDS, GALILEO, QZSS, NFC
- USB Type-C 3.2
- Battery:
- Li-Ion 5050 mAh battery
- Fast charging 30W
- Qi wireless charging 23W
- Dimensions
- Size: 162.6 x 76.5 x 8.8 mm (6.4 x 3.0 x 0.3 in)
- Weight: 213 g (7.5 oz)
- Additional Features
- IP68 water/dust resistance rating (1 meter underwater up to 30 minutes)
- Stereo speakers
- Fingerprint (under display, optical)
- Laser autofocus (only on wide and telephoto cameras)
- Temperature sensor
