Battery
Domande popolari nel forum
Fai una domandaNon ci sono domande. Puoi essere il primo a porre una domanda!
Strumenti
Questi sono alcuni strumenti di uso comune usati per lavorare su questo dispositivo. Potrebbe non essere necessario ogni strumento per ogni procedura.
Background
The Enabot EBO SE is a multi-functioning “Surveillance Robot.” The Enabot EBO SE was released in March 2021 and is a multifunctioning robot that can take photos and video, be used for security, act as a two-way communicator, and be remote-controlled. The enabot EBO SE is one of two Enabot robots, there is another variation the EBO Air. Like the SE the Air has a 1080p HD camera for photos and video. The EBO Air has an AI smart feature which differentiates it from the EBO SE. To distinguish the two, look for the name on packaging or on the device itself.
Identification
The Enobat EBO SE is distinguished by its lightweight construction and has a display with LED indicators. The Enobat EBO SE also has a number of connectivity features, including cellular, Bluetooth, and Wi-Fi, which allow for easy internet access and communication. It is advisable to verify the precise model, including the name and number, by consulting the device's literature, packing, or manufacturer's website. By doing this, customers may increase the likelihood of a successful repair experience by ensuring they have access to the necessary repair information that is precisely customized to their Enobat EBO SE device.
Technical Specifications
- Features
- Remote Control, Voice, Photo & Video, Security, Multi-Members
- Resolution
- 1080p
- Camera Angle
- Diagonal: 118°
- Horizontal: 98.5°
- Vertical: 62.5°
- WIFI
- 2.4G
- 5G
- Speed
- 20 cm/s - 60 cm/s
- Crossing Height: 5-6 mm at normal speed
- Uphill slope: 4°
- Size
- Width: 95 mm
- Height: 89.2 mm
- Length: 95 mm
- Weight
- 260g – 300g
- Battery
- 2500 mAH
- DC-5V/2A
- Battery/Charging Duration
- Battery: 4-7 H
- Charging: 2-3 H
- Maximum Memory Supported
- 256G
- Implementation Standards
- GB8898-2011
- Waterproof Grade
- Not Supported
