Camera
Domande popolari nel forum
Fai una domandaNon ci sono domande. Puoi essere il primo a porre una domanda!
Strumenti
Questi sono alcuni strumenti di uso comune usati per lavorare su questo dispositivo. Potrebbe non essere necessario ogni strumento per ogni procedura.
Troubleshooting
if you are still having issues with your EchoMaster we have a troubleshooting page that you can access here.
Background
The EchoMaster MRC-WLP43 is a wireless backup camera. The monitor attaches quickly to your windshild or other smooth surfaces.
The LCD screen provides a clear, crisp view, day or night, of what’s going on behind your vehicle. License plate frame camera easily attaches to your vehicle using the same two screws that hold your license plate in place.
Here are some key features:
- Wireless monitor attaches quickly to your windshield or other smooth surface
- IP66 rated water/debris-proof camera for all conditions
- Power adapter with dual USB port to power your monitor & charge phone at the same time
There isnt much information on the history of this device, but you can find more facts and information about the EchoMaster at this website or at your local Best Buy.
Identification
The EchoMaster is black in color and has a silver lining the outside rim of the display. The camera is on a flat metal rod that sits at the back of a vehicle. The monitor also has three buttons on the front and a small blue light on the left side of the buttons. You can find this device through the EchoMaster's model number MRC-WLP43.
Technical Specifications
Camera
- Sensor: CMOS
- LEDs: No
- Illumination: 1 Lux
- Viewing Angle: 120°
- Mirror Image: Yes
- Normal Image: No
- Water/Debris-Proof: IP66
- Audio: No
- Power Supply: DC12-24V 1A
- Current: <300 mA
- Operating Temp: 14°F - 140°F/-10°C - 60°C
- Dimensions - mm (in): 68 (2.7) x 24 (1) x 40 (1.6)
- System: NTSC
- Tv Lines: 480
- Resolution (HxV): 680 x 480
Monitor
- Screen Size: 4.3"
- Aspect Ratio: 16:9
- Power Supply: DC 5V 1A
- Resolution: 640x480
- Luminance: 250 nits
- Contrast: 400
- TV Format: 400
- OSD Languages: Yes
- Video Inputs: 1 input
- Audio Input: 0
- Triggers: 1
- Current: 1
- Parking Guidelines: Yes
- Connection Type: Micro-USB
- Dimensions - mm (in): 120 (4.72) x 25 (1.0) x 20 (0.78)
Built-in Transmitter
- Frequency: 2.4G ± 0.3
