1 Diagramma
Nessuna Risposta Punteggio 0 |
Heating up then shutting off so no steam |
Modelli
0LMB150NA
Background and Identification
The Earlex Wallpaper Steamer 0LMB150NA is an electric wallpaper steamer identified by model number LMB150. The LMB150 wallpaper steamer is designed to remove all types of wallpaper and vinyl using only water. It can be used for residential and professional use. A wallpaper steamer is an electrical device that boils water continuously to produce steam. The steam passes through a narrow bore tube to a faceplate. The face plate is held against a wallpapered wall and steam passes through the paper and saturates the backing paper, partially dissolving the wallpaper paste. This process allows the wallpaper to be pulled from or scraped off the wall.
The wallpaper steamer includes a built-in step that helps users reach higher areas. It also features a five-meter (16-foot) anti-kink Coolrun hose that allows users to reach most ceiling heights. It has a two-gallon capacity tank that will provide approximately three hours of steam time with one fill. The LMB150 wallpaper steamer includes a reinforced threaded pressure relief cap for user safety. It also has a neon on/off switch and two thermal protection devices. An integrated water level indicator is located on the front of the steamer, underneath the pressure relief cap.
The LMB150 wallpaper steamer includes an 11- by 13-inch steam plate, a 6- by 3-inch steam plate, and a 16-foot power cord. The LMB150 model includes the name “Earlex” with a red flag above the name on a sticker on the side of the steamer.
Technical Specifications
Assembled Depth (in.): 18 in
Assembled Height (in.): 16 in
Assembled Width (in.): 18 in
Weight (lbs.): 21.2 lbs
Amperage (amps): 12.5 amps
Tank Capacity: 1.9 gallons
Voltage (volts): 120V
Watts: 1500 W
