1 Diagramma
Domande popolari nel forum
Fai una domandaNon ci sono domande. Puoi essere il primo a porre una domanda!
Background and Identification
The Diamabrush Cutting Tool Disc model HD931601212 is a 16-inch 25-grit coating removal disk. The Diamabrush Cutting Tool Disc model HD931601212 is also called the Coating Removal Tool and Riser. It is designed for use with automatic scrubbers and flooring machines. The disk is meant to remove glues, adhesives, thin-set, and thin-mil epoxies, and other floor coatings. Diamabrush advertises that this model is designed to prevent the tool from clogging or loading-up to provide consistent removal.
The Diamabrush Coating Removal Tool and Riser should be used on existing, standard equipment such as flooring machines and automatic scrubbers. Users do not need to apply any chemicals for use with the Diamabrush system. The Coating Removal Tool removes coatings and profiles concrete with a solely mechanical removal system. It uses diamond abrasives with a resin backing for sanding, grinding, and polishing.
When purchased from Home Depot, the Diamabrush Coating Removal Tool and Riser comes assembled with the NP9200 Clutch Plate and Riser for universal fittings. Replacement blades can be purchased from Diamablade or from Home Depot. The disk is 16 inches in diameter and 4 inches in height.
The Diamabrush Coating Removal Tool and Riser disks are typically beige in color and includes a series of diamond-coated abrasive disks around the perimeter of the disk. Each disk includes two bolts that can be removed to replace individual disks.
Technical Specifications
Dimensions:
- Product Height (in.): 4
- Product Length (in.): 16
- Product Width (in.): 16
Details:
- Abrasive Material: Diamond
- Application: Heavy Duty
- Arbor Size: 16"
- Arbor Size (in.): 16"
- Backing Material: Resin
- Grit: 24
- Power Tool Accessory Type: Sanding/Grinding/Polishing Accessory
- Sanding Grade: Coarse
- Sanding, Grinding, and Polishing Accessory Type: Diamond Grinding Wheels
- Tools Product Type: Power Tool
- Wheel Diameter (in.): 16"
