2 Risposte Punteggio 10 |
It can't start |
2 Risposte Punteggio 3 |
Black smoke and mileage problem 10 years vehicle but its very smooth r |
3 Risposte Punteggio 4 |
Why motorcycle 50-60 speed after started shake |
14 Risposte Punteggio 6 |
Start problem Bettry full charge Handle problem Kick problem |
Engine Type
Single cylinder, 4 stroke, air cooled
Displacement
94.38 cc
Compression ratio
9.8 : 01
Max. Power (Ps @ RPM)
7.7 @ 7500
Max. Torque (Nm @ RPM)
7.85 @ 5000
Clutch
Wet multiplate
No. of gear
4/5
Gear shift pattern
All down
Fuel tank capacity
8 liter full (2.3 liter reserve)
''Dimension"
Length 2040 mm
Width 760 mm
Height 1087 mm
Wheel base 1305 mm
Ground Clearance 162 mm
Kerb weight 115 kg
