Power Button Dead?
Domande popolari nel forum
Fai una domandaNon ci sono domande. Puoi essere il primo a porre una domanda!
GENERAL
Display Type LCD monitor / TFT active matrix
Native Resolution 1280 x 1024 at 75 Hz
Contrast Ratio 500:1
Color Support 16.7 million colors
Controls & Adjustments Brightness, contrast, color balance, clock
Dimensions (WxDxH) 16.6 in x 6.9 in x 17 in
Horizontal Viewing Angle 140
Vertical Viewing Angle 140
Pixel Pitch 0.294 mm
Brightness 250 cd/m²
Horizontal Refresh Rate 80 kHz
Vertical Refresh Rate 75 Hz
Manufacturer Acer
CONNECTIVITY
Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15)
POWER DEVICE
Nominal Voltage AC 120/230 V
Frequency Required 50/60 Hz
Power Consumption Operational 48 Watt
DISPLAY
Image Brightness 250 cd/m2
Image Contrast Ratio 500:1
Color Support 24-bit (16.7 million colors)
Type LCD monitor
MISCELLANEOUS
Compliant Standards TCO '99
Power Consumption Stand by / Sleep 3 Watt
Power Supply internal
INTERFACE PROVIDED
Qty 1
Connector Type 15 pin HD D-Sub (HD-15)
VIDEO
Video Output none
MECHANICAL
Flat Panel Mount Interface 100 x 100 mm
DIMENSIONS & WEIGHT
Width 16.6 in
HEADER
Brand Acer
Product Line Acer
Model AL1912
Packaged Quantity 1
Compatibility Mac, PC
PROJECTOR
Max V-Sync Rate 75 Hz
Max H-Sync Rate 80 Hz
TV TUNER
TV Tuner Presence No
GENERAL
Manufacturer Acer
Acer AL1912 - LCD monitor - 19"
Part Number: ET.L2302.011
MSRP: $309.55
